wheel locks
BigDanTheMan
02-12-2007, 11:21 AM
dudes -
where am i going to find a replacement for the lug nut lock key that i've apparently lost over the years? the lug locks i have work with this pattern that looks like a worm's path through an apple and the key fits the lug wrench socket and fits into the "path". does that description make sense?
at any rate it seems unique. would the local big o have a selection of adapters? how else could i get this bitches off?
2crunk
02-12-2007, 04:53 PM
is it a factory lug key that you need? if so the dealership might be able to get you one. if not, you could try some sockets and see if you can strip it off the wheel, not recommended but as a last resort.
351wStang
02-13-2007, 12:56 AM
Hammer and screw-driver. Then get new lug nuts.
BigDanTheMan
02-13-2007, 12:21 PM
hammer and screw driver?
351wStang
02-13-2007, 12:57 PM
...hold the screw driver on one of the "teeth" on the lock nut, then hammer it around to loosen it.
GTStang
02-13-2007, 10:42 PM
Or an AirJack would be faster :evillol:
But I have had good luck with taking a hammer and hammering a socket over it to get wheelocks off.
BigDanTheMan
02-14-2007, 02:29 PM
so jam a flat head into the "apple worm path"
BigDanTheMan
ps nice to see you all again.
smurfmobile
03-01-2007, 10:36 PM
tool trucks and auto parts stores carry large sockets with internal cone threads that are made for lugnut removal.
2crunk
03-02-2007, 11:06 AM
also known as "twistys"
