2000 gtx ram air...pwr windows... heater fan
kygirl
02-10-2007, 07:07 AM
2000 Gtx Ram Air
I Was Wondering If You Could Help?? I Have A Couple Questions.
I Have 75,000. Miles On My 2000 Gtx...
1) Last Year Had To Replace The Switch On The Driver's Pwr Window.....it Worked Up Until A Bit Ago....now The Front Driver Side Is Getting Slow...sometimes Stuck Again.....but Will Roll Up Eventually..along With The Rear Driver Side....it Is Stuck And Won't Roll Up At All. It Will Roll Down But Won't Go Back Up. I Have It Taped In Place Right Now.... I Don't Know If It Is The Motor Or Regulator?? And Do I Need To Replace On Both Doors Or Just The Front Driver ?
2)i Have The Climate Control Ac/heater......when I Turn On The Fan As High As It Can Go....it Only Blows Out Like It Is On A 2 Or 3 Setting....not A 5. The Heater And Ac Work Fine...but When I Put It On Any ( Def./panel/floor) It Doesn't Blow Air Like It Should For The Highest Setting..the Fan Runs Fine.....but The Air Just Isn't Reaching It's Capacity Like It Should...someone Said There Is A "door" And Maybe It Isn't Opening All The Way..any Suggestions?
3) My Service Engine Soon Light Stays On.....not Everyday...but Say I Drive It 7 Days....it Stays On Atleast 3 Or 4. Autozone Said It Was Some Sort Of Sensor....oxygen Maybe?
4) Last ?...ha Ha.....i Had The Gtx Ram Air Emblems On The Doors And They Have Fallen Off.....is There Some Way To Get The Adhesive Off The Car From The Emblem...it Is Like A Hard Putty Sub.......and Do You Know Where I Can Purchase The Emblems To Replace Them?
Knock On Wood There Are No Other Problems....but My Major One Is My Pwr Window's ....and My Blower.
Any Help Or Suggestions At All Will Be Greatly Appreciated.....
BNaylor
02-11-2007, 03:02 PM
Welcome to AF.
That is a lot to digest but maybe we can help on a few of your problems.
On the scan from Autozone, it is best to get the odb-ii DTC codes and write them down. Then post here so we can review.
On the power windows, it sounds like a combination of problems from a possible bad track to the motor and regulator assembly.
For debadging and getting the rubber adhesive off try a hairdryer and heat the adhesive residue up, then use your fingers and it should roll up into a ball or you can pick away at it. Repeat, if necessary. Then you can use WD40 sprayed on a rag to get the remainder off.
On the HVAC blower you may have a problem with accessory vacuum from the intake system so check the plastic vaccum line that runs along the firewall, loops by the battery and main fuse box and then into the main wiring harness going into the firewall. Are all five fan positions working? Also, you can remove the passenger intake cowling to check for any obstructions in the intake for HVAC or a clogged cabin air filter, if installed.
