swap sohc zc into 90 crx hf Problems!!!
EF_Mit
02-09-2007, 03:39 PM
car is choking whenever i step on the gas....i found a wire behind the manifold and its not hooked up and i cant find the wire to hook it up to..could that be the problem ?? is the hf wire harness the same as the crx si??
CRXperiment
02-09-2007, 07:52 PM
Any check engine lights?
Are your IACV, FITV, TPS and IAT senors hooked up?
Pics of the wire help.
2poor2tune
02-10-2007, 02:35 PM
yes check the map sensor also. make sure the vaccume off of it is going strit to the vaccume nipple on the intake mani.
YZ125rider21
02-14-2007, 12:58 AM
hf and si harness are similar, I think the 88 and 89-91 are the ones that have diff plugs if I am correct...take a picture of the left over plug and we can tell you where it goes I just did this swap for a friend into a dx...
