Im Really Confused!
typingmime
10-01-2002, 12:00 AM
I want a project.. so i am looking for a striped block.. new or used.. i want to put it in a 99 civic im not sure what size block i should get to start building.. and im not sure where i should get it from:rolleyes: but i know that i want to build it my self all i need to do is start with the block and all these codes and numbers are messing with my head.. b16a b16b h22 b16ba2 not sure what it all is for .. i just want to know what i should get and where i can get it so i can get started... as you can tell i not to up on imports so be kind please ;) thanks!
hope someone can help.. :)
Belldandy
10-01-2002, 12:11 AM
Well B18c is the engine for the integra gsr it is a 1.8l engine and it will bolt directly into your car with little if any modifications. The B16a is a 1.6l engine that came in Honda Civic SI and it will bolt directly in as well. The H22a is a prelude engine. They have kits to make this bolt in but personally I think this isn't the best choice since it's a little on the heavy side you will probably have to do something to the suspension due to the excess weight. Thats all I can think of.
Oh yeah a1 and a2 for the B16 is basically first generation and 2nd generation engines.
Belldandy
10-01-2002, 12:12 AM
I was about to get a b18c for my civic but I have a second project I'm thinking about starting so I abandon that idea. I think it's a little better than b16 since it's a larger engine but the b18 is expensive while the b16 is cheap. Well wish you best of luck.
typingmime
10-01-2002, 12:50 AM
:D belive it or not that helped a LOT!! thanks! now the only question is .. Where do i get it?... i know that i dont want a crate engine so my search is pointed to finding just a block.. no heads, cams, pistons nothing.. hehe im in for a search i think.. if you think of any place that i can order one.. let me know .. thanks for the advice! :)
Belldandy
10-01-2002, 12:59 AM
oh good. Well try ebay. I don't know if u like that but I would buy it off ebay if I wanted one. They sell a lot of blocks or whole engines. If u want relaible dealers that sell engines then ask me later. like in the search type in b16a or b18c or something
gunnmen01
10-03-2002, 11:24 AM
Or try a local junkyard, they may have a motor you can buy...
gunnmen01
gunnmen01
civickiller
10-05-2002, 11:23 PM
if you wanna build a totally bulletproof block then i say buy a built block from jg. i am pretty sure they sell short blocks, all decked and balanced and blueprinted. or you can just buy a complete block which will be cheaper in the long run, and it cna handle 30 psi of boost.
typingmime
10-06-2002, 06:33 PM
where online can i get a jg block?
