Help Me !!!!!!
JEEP GURL 21
02-09-2007, 12:01 AM
I Have A 97 Jeep Wrangler 4.o I Just Went Out Side To See Antifreez Everywere I'v Replaced The Water Pump About 7 Months Ago Along With A New Radiator So I Am Not Sure What Could Be Wrong So If Anyone Has Any Suggestions That Would Be Great
Lindsay~
Ray H
02-09-2007, 08:56 PM
Lindsay~
Theres a hundred places that could leak antifreeze. Your best course of action is to wash the engine and underside off, let it dry and then run the engine to see where its leaking from. My first thought wouldve been the top seem of the radiator and then the water pump, but you say both of those are new. It could be any one of a number of hoses, a freeze plug, head gasket, overflow bottle, radiator cap, the list goes on. You gotta find out where its coming from.
JEEP GURL 21
02-09-2007, 09:18 PM
I Put A New Bottom Hose On Today Along With Clamps I Put Antifreez In It Again And It Leaked Once Again From What I See When I Am Under Neathe It,its Coming From Behind The Belt Some One Told Me Maybe A Gasket.
Ray H
02-10-2007, 09:23 AM
Did it leak there before you had the water pump put on? If it started the same time the water pump was installed, I'd guess the water pump gasket is the problem. In that area though, it could be a hose clamp, water pump or WP gasket or thermostat gasket.
