camshafts
jester151315
02-04-2007, 04:58 PM
Why is it that a DOC produce more horse power then a single cam? At least thats is what I am told, but when i asked him why, he didn't know.
Mr. Luos
02-04-2007, 05:33 PM
They don't always make more power.
They have several more internal moving parts which require power to drive. Honestly, they also aren't as efficient as a typical pushrod motor.
They do make good power though. It all depends on heads, cam(s), etc...
poormillionaire2
02-04-2007, 07:10 PM
One advantage of dual cams instead of a single, is the use of more valves. Typically, 4 valves per cylinder will have improved flow over 2.
Mr. Luos
02-04-2007, 09:36 PM
Sorta.
DOHC limits how much lift you can run. Most stock DOHC motors will move more air. Most modified 2-valve pushrod motors will move more air.
Depends on the application.
