91 Civic 1.5 Intermittently Cuts Out
biohazardbill
01-30-2007, 07:32 PM
Hi, new to Hondas so I figure I would ask here.
This is a problem that started just recently, but I can be going 60 miles per hour down the road, or idling and it seems as though the car wants to die. For a split second.
Yesterday it actually died on me driving down the road, so I coasted to a stop in a parking lot... turned it over for about 6 seconds and it fired up and I drove home. Today.. started cutting out again...
After it cuts out... seems fine... revs nice... just every once in a while it dies.
I replaced coil, battery, and it has had a tune up over the past 6 months...
It seems as though I lose spark (if I had to diagnose a Chevy)... so anything I should look for or ideas? Hondas are a little more complex than an older small block :)
Any ideas appreciated..
arodg25
01-30-2007, 09:41 PM
if you are in fact losing your spark, it could possibly be your igniter.
biohazardbill
01-30-2007, 10:36 PM
Where is the igniter located?
CRXperiment
01-30-2007, 11:46 PM
Its a module in the distributor, underneath the coil. When the ignitor goes bad, you get symptoms like yours: intermittent no spark. I'd say check it out.
