Starting problems on 2000 Venture
mgotvald
01-29-2007, 02:10 PM
Primarily while on a short errand when I try to start my van the lights and bells work, but the engine does not turn over. There is no clicking or other noise. A new battery didn't help. A few times I shook the battery and the van then started. I replaced the starter, as the solenoid seemed to be the problem, and it solved it for three months until last week. I replaced the starter again and will see if the problem continues. Has anyone else encountered this problem and have suggestions?
tec5120
02-07-2007, 10:34 PM
check the conn from the pos batt to the relay fuse box right obove the batt, there is a red cover over it. remove the nut wire brush the crap out of it get some dielectric greese and re tighten the nut should fix the prob..............
