cannot get airbag connector off
benblank04
01-26-2007, 04:44 PM
I am in the process of replacing my airbags, the passanger side is pretty simple to remove, but I cannot seem to get the connector off of the airbag. Is their a certain way to get the connector off? Also if anyone has replaced the airbag in the steering wheel how do I remove that?
xeroinfinity
01-27-2007, 07:59 PM
Sqeeze and unplug its that easy.
The drivers air bag you need to remove the screws in back of th esteering wheel. The horn connector I believe you twist contrclockwise.
Just remember two make sure the battery is disconnected and the air bag fuse is pulled before you install the new one.
And you will need a ABS capable scann tool to clear the ABS codes after the work is done.
Good Luck
Good Luck
oldmike
01-28-2007, 05:21 AM
Benblanko4,
Have you been able to get the old bags out and new ones in? If not I will write up what I am doing in the same situation currently. It is with a 2001 Grand Am, but I think they work the same.
Mike
Mike
vamc
02-02-2007, 07:33 PM
When doing all of this, please disconnet the batt. or the air bag will go off.
xeroinfinity
02-02-2007, 10:37 PM
I believe we covered this in the second post :cwm27:
