Tire speed rating
NuEra
09-26-2002, 06:03 PM
I want to know if the speed rating means you can't go over the certain speed because the tire will burst. Or will it just get hard to steer?
NuEra
09-26-2002, 06:04 PM
sorry I put this in the wrong section but feel free to answer my question
-=BOOMER=-
09-26-2002, 06:40 PM
Speed rating is just that
Its the maximum speed (heat) that tire had been tested and known to work too.
Running faster then a tire is rated is risky because yes they can burst or a lot of bad things. Like bubble.
Remember the faster you go the hotter your tires are going to get.
YogsVR4
09-27-2002, 01:44 PM
Originally posted by dgonzals
The speed rating of any tire is a measurement of the top safe speed for any given tire. It is also an indication of how the tire will perform at lower speeds. A higher rated tire will give you better traction and improved steering response even at 50mph.
Below is a listing of common speed ratings:
Q=99 MPH, 160km/h
S=112 MPH, 180km/h
T=118 MPH, 190km/h
U=124 MPH, 200km/h
H=130 MPH, 210km/h
V=149 MPH, 240km/h
Z=149 MPH, 240km/h and over
W=168 MPH, 270km/h
Y=186 MPH, 300km/h
It is not recommended to downgrade your tires to a lower speed rating than of the OEM tires that came with your vehicle at the time of purchase. Also, never mix tires with different speed ratings on your vehicle.
Bingo.
I will say you can juggle the W,Y and Z tires for most performance cars as long as you dont push them to the limit all the time.
BeEfCaKe
09-28-2002, 01:46 PM
What bout ZR? What is that?
j.fuggi
09-29-2002, 10:37 PM
the one thing i don't under stand is why are Z rated tires for 149 and OVER? how much over? w and y are rated higher but not over.
what tire would you put on a 200+mph skyline?
BeEfCaKe
10-01-2002, 10:28 PM
Slicks
j.fuggi
10-01-2002, 10:35 PM
let me rephrase.
what DOT street legal tires, with tread would you put on a 200+mph skyline.
luti
10-02-2002, 08:37 AM
The slicks that have the one single tread running down the middle.
