FYI-95 T&C engine swap
ninemmeter
01-20-2007, 02:47 AM
I recently bought a 95 T&C with a bad 3.8 in it.The van has the digital dash.I had a 93 Caravan sitting around with a good 3.3 in it.The Caravan had a non digital dash.I put the 3.3 into the T&C and after hooking it all up it would not start.Come to find out,the wiring and the cam sensor and the O2 sensor were different,so it blew the ECU out.Had a heck of a time finding a T&C with a digital dash at the local salvage yard,but after I finally found one I got the engine wiring harnesses and ECU out of it and after installing it and cycling the ignition 50 times to reset the ECU,the van started and has been trouble free ever since.Just a little info in case someone else decides to do this particular engine swap.Have a great day all!!!!!
