Speaker Question
JaysZ24
01-18-2007, 09:26 PM
Ok my stock 6x9 speakers r really really shitty and i was looking at so to buy and i found these on the internet
http://www.futureshop.ca/catalog/proddetail.asp?logon=&langid=EN&sku_id=0665000FS10040437&catid=#
I wanted to know would these work in my car or would i need and amp to power them also i do have a JVC cd player if that makes a difference
thanks for any help
Jay
LPlanert
01-18-2007, 11:58 PM
Well, I couldnt get the link to work for somereason, so this is my 2 cents here...
Depending on how big the speakers are, you might need a small amp. if there in the few hundred range, you could probly get by with out an amp, but I would use a small one. figure out the RMS value, a good guess is if they dont say it, figure about half the peak power. If it is a 300W speaker, dont get a 300W amp, and have it on full blast, From experiance, you will blow it playing the speaker at constant peak power.
Pritty much, if you have a good aftermarket radio, and rather small, but good speakers, you shouldnt need an amp, but if there bigger, then your radio wont be able to power them, and they will sound like shit.
millrtime
01-19-2007, 01:47 AM
you typically wont need an amp for any aftermarket speakers. most aftermarket radios put out at least 100 watts, which is enough to sufficiently power most speakers, but they do sound better with a small amp. i say just get the speakers and install them, see how they sound, and then use ur judgement on whether u need a amp or not.....
01Cavy
01-19-2007, 02:31 AM
Replace all four speakers in your car, and get a small mulit-channel amp (4-channel), and run it to all speakers. It's not necessary, but will help them to sound better.
JaysZ24
01-19-2007, 04:29 PM
Ok thanks you guys for all the responses u helped me out alot
spudracer73
01-19-2007, 06:59 PM
i just replaced all four stock speakers in my car with pioneers in front and rear. I also put bass blockers on the front speakers so i won't blow them because as you know they are 4 by 6 and small little speakers. I get a very clean clear sound.
JaysZ24
01-20-2007, 01:40 PM
Ya i was thinking about replacing the speakers in the front too
