Help! Power steering fluid puddle under car!
guitarfish
01-16-2007, 05:32 PM
It's been a day...
My son's 97 GP, the idler pulley broke off at 65mph this morning. Being only a few miles away, he drove back home and parked it in the garage. Tonight I replaced the pulley and put a new belt on, fired it up, everything seemed OK.
However, once I backed out of the garage, and discovered a 12" wide puddle of PS fluid on the ground. Argghhh!!
I wonder if something got damaged when the pulley came off.
Any suggestions on where I should start? FWIW, the power steering is still working for the moment.
*EDIT* Had a friend look at it tonight - he says oil is coming out the PS pump main seal. Well, that answers that.
GTP Dad
01-17-2007, 05:09 PM
Yep! New pump time. Make absolutely certain that you bleed the lines and pump otherwise you can burn up the new pump.
guitarfish
01-17-2007, 05:46 PM
I just this second sat down, the pump replacement is ... DONE!
Bought a pump and borrowed a pulley puller from Autozone, my son and I did the job. We did the bleed procedure too, so far so good.
