2005 or 2006 Lift
ScottyB1
01-16-2007, 05:16 PM
Has anyone used the coil spring and shackle lift on an '05 or '06 to lift it. Are shock replacement and added length brake lines a necessity or just optional? Looking for some advice if you know of anyone with experience in this area.
Thanks,
lj1983
02-17-2007, 01:16 PM
i have the coil/shackle lift. upgraded brake lines are not needed with the shackle lift, probably with the AAL.
upgraded shocks are not needed, but if you go off-road at all, extended ones in the rear are very helpful. I think the stock shocks limit you in the rear as it is. as for the front, i dunno. there weren't any replacement shocks for the front when i put the new coils in, so they max out alot....
overall, i like the lift, but if i had to do it over again, i might just go with radflos and TC ucas in the front.
ScottyB1
02-19-2007, 12:06 PM
Thanks for the reply. I've been waiting for that one for some time now. I will probably opt for the coils and shackles. However, forgive my ignorance, but what are the radflos and TC ucas? Would that be add-a-leaf rear springs and front upper control arms?
Thanks again,
lj1983
02-19-2007, 01:07 PM
radflos are replacement coil-over shocks for the front. the AC springs ride kinda rough, and you can get alittle more lift out of the radflos.
