Replacing Power Lock Actuators
badbrakes
01-14-2007, 07:49 PM
This post may be of interest to the 'occasional DIYfer' such as me. I have an 03 Odyssey and within a month or so I had two power locks 'go'. One on the front passenger door and one on the driverside sliding door. This of course occurred after the warranty had expired... at first I just decided to just live with it but after a while of constantly walking around the car to lock/unlock the doors manually, I decided to fix them.
I started with the front passenger door... took me the best part of an hour and a half to dismantle it. You first have to take the door panel off... in my case, I didn't use a door panel tool and had no problems... I just used a flat screwdriver and the panel's clips popped off easily without breaking. You need to disconnect and take out the speaker, window switch and power lock switch. You then have to take 1/2 the plastic shield off. Then you'll see your lock actuator right against the door underneath the door lock mechanism and behind the window railing. Rather hard to get to it. You need to remove the window railing and dismantle the lock mechanism from the door itself... you can't just remove the actuator as it is screwed to the lock mechanism and of course the screws are facing the wrong way. The door lock actuator was about 55$ cdn. Reinstalling everything went quicker (about an hour).... have to be careful when reinstalling that you pay attention to how you reconnect the cables... make sure you don't leave them in path of the window railing...
The following day I tackled the sliding door power lock. Much easier job. No switches on door panel... comes right off... didn't use a door panel tool either. The actuator is also screwed to the lock mechanism and you also have to take the full lock mechanism out... however, unlike the front door, you have easy access to the lock mechanism and it's only held in place by 3 screws. The lock actuator is around 65$ cdn with taxes... make sure you specify what Odyssey model you have as the base and higher models have different lock actuators. In terms of how long, I'd say it took me 30 minutes to dismantle everything and 20 minutes to put everything back together... much much easier then front door.
BTW, the folks at the Honda parts counter told me these actuators have a tendency to break easily... Now I'm just hoping my other door actuators won't break... especially the front door.
badbrakes
08-06-2008, 09:20 AM
I had yet another lock actuator go on my van (above post was 1.5 year ago). Now I've had to replace 3 out of 5 actuators on my van. Anyone else has run into that kind of problems or is there some kind of weird 'lock actuator' curse on my van ??!!
This time I took pictures. This is the passenger sliding door. Not too hard a job compare to front doors.
Here what the lock actuator looks like (white part on right). Part on the left is not the actuator. Don't bother dismantling the lock actuator (it actually can be opened up)... dealership sells as one unit - 50$ cdn.
http://i36.photobucket.com/albums/e37/badbrakes/IMG_1902.jpg
Here's how the lock actuator and lock mechanism fit together:
http://i36.photobucket.com/albums/e37/badbrakes/IMG_1905.jpg
Here's what it looks like in the door. Only three bolts retain the mechanism. Top 2 bolts don't need to be removed - just loosened - once you've removed the bottom bolt, slide the entire unit up to remove.
http://i36.photobucket.com/albums/e37/badbrakes/IMG_1908.jpg
Here's the trim panel (inner view). Rather easy to remove. Just put your fingers behind it (where the white push brackets are located) and pull gently - should come out easy. Remove upper window trim prior to removing the door panel - can also be removed only by pulling gently.
http://i36.photobucket.com/albums/e37/badbrakes/IMG_1909.jpg
Good luck.
