AIR DRIED BEEF DOG FOOD
1993 lude stick hard to shift to 1st gear
gelcol
01-13-2007, 08:23 PM
I have f-22a engine don't know the transmission well .
when the engine is turn on, its hard to shift to 1st gear have to shift it to 2nd gear first then 1st then it will engage and run.
I press/pump the clutch pedal many times still did'nt help.
. and sometimes at the speed of 40miles/hr its hard to go to the 3rd gear after I place it on nuetral after pressing the brake it will make a grrrrr sound before it will engage. easy to shift to the 4th ,and 5th gear,
after I place it to neutral it won't go back to 5th gear while runing at 65miles/hr. has to engage to 4th gear again before 5th.
when the ignition is off, it shift smoothly to all gears.
I check the brake fluid its in the right level
J-Wat
01-15-2007, 11:16 PM
sounds like the clutch isnt disengaging all the way, check the system for leaks and bleed it, could be something else but its a good place to start
Gohan Ryu
01-16-2007, 02:21 PM
Bad synchros - common Honda problem. Sometimes my lude does the same thing. If I let the clutch out slowly while gently pushing the stick into first gear it will go into gear.
gelcol
01-19-2007, 10:53 PM
thankz! where is the syncros loc. at?
gelcol
01-19-2007, 10:55 PM
Bleed like the brake system.
J-Wat
01-20-2007, 01:19 PM
no, bleed the clutch system... the bleeder is on your slave cylinder by the transmission
Gohan Ryu
01-23-2007, 01:23 PM
They're built internally in the transmission.
