97 mustang has problem with gearshift
goongrinch
01-13-2007, 07:00 PM
1997 v6 automatic trans, well the cruise control was not working on the car, after i got underneath the dash i saw a peice disconnected, i plugged it back and and ever since doing so it fixed the cruise control but now makes the gear shift selector hard to move tru the gears, if i disconnect the part of the cruise control its just fine, the part im talking about is on the brake pedel, im gessing there is some adjustment i need to do but im not sre what exactly it is.
351wStang
01-14-2007, 12:33 PM
I have no clue on this one really. All I know to tell you is to get back under the dash and look for anything obvious. Also follow the shifter cable, maybe while you where under there you got it in a bind somehow? I'm not sure, but if you cant find anything you will probably have to take it to a shop and let them have a go at it. I doubt this is a very comon problem so you probably wont hear much about it here. You can try to google it though.
goongrinch
01-18-2007, 07:06 PM
ok i got around and proof read what i originally posted and realized it made no since...heres what i ment to type
1997 v6 automatic trans, well the cruise control was not working on the car, after i got underneath the dash i saw a peice disconnected i assume it was the deactivator switch as it is on the arm of the brake pedel, i plugged it back in and it fixed the cruise control but now makes the gear shift selector button hard to push in from park only, if i disconnect the deactivator switch the cruise control will not work and the button on the gear shift will push in just fine, im guessing there is some adjustment i need to do but im not sure what exactly it is.
351wStang
01-19-2007, 01:01 AM
Is the brake pedal adjustable in the '97s?
goongrinch
01-25-2007, 06:35 PM
ok well i finally got around to it and i fixed the problem, the 2 wires going to the brake light switch were broken and brittle, i put new wire and connectors on and plugged it in and now everything is fine with the shifter.
