Going to go scrapin
Cfmotorsports
09-24-2002, 05:16 PM
I am going to go to the local salvagae yards tommarro and check out a few things, i found one that say they have 5 civics well what i wanna know is what parts will interchange like what do i need to find to get rear dick brakes on my 90 si what kind of car and what year and just how much stuff do i need?
What year honda do i need to find to get the console that has the arm rest that i see alot of people with?
what cars would have the b16 in it or a zc dohc in it?
and i heard some where that the 4dr civic has larger brakes than than the hatch is this true and what does it take to put them on the hatch?
Well thats all for now thanks for any info.
gunnmen01
09-24-2002, 05:59 PM
RR disc brake swap will be a 90 to 93 integra.you'll need the whole rr. trailing arms, lower control arms and the emergency brake cables. For bigger front brakes you'll need a 90-91 EX sedan the whole knuckle,caliper, rotor,and brakeline. For the center console, a 94 and newer integra the console and both mounting brackets underneath it. B16 will be a little more work and expensive...
gunnmen01
Cfmotorsports
09-24-2002, 07:55 PM
on the front brakes is the diff between the rotors that much, is it a worth while conversion. sounds like that could be $$$ if its not a bigg dif. thanks
