installing an alarm 2003 civic hybrid disarm the factory keyless entry
dealseaker
01-08-2007, 02:09 AM
where/how do i disarm the factory alarm/remote locks? I have installed one in our caravan, alarm I chose is a mars33 Any info or recomendations will be appriciated, as to where/what wires I need to pay special attention to, easy access to kick panels/ wires.
BrodyP
01-08-2007, 07:30 AM
Installing alarms tricky job here is a wiring chart if that helps. Also the factory security control module is located under the driver's side of the dash. This was all for an 02 Lx I would think it would be the same.
12volts white + ignition harness
Starter black/white + ignition harness
Second Starter N/A
Ignition black/yellow + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory black/red + ignition harness
Second Accessory white/red + ignition harness
Keysense red/white - ignition harness
Power Lock white/blue - gray plug above drivers kick
Power Unlock white/green - gray plug above drivers kick
Lock Motor yellow/black back of the fusebox
Notes: In the top left plug.
Unlock Motor yellow/green back of the fusebox
Parking Lights+ red/black back of the fusebox
Parking Lights- blue factory alarm plug
Notes: The factory alarm plug is a green plug above the drivers kick panel.
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light green + driver kick panel
Door Trigger - factory alarm plug
The drivers door trigger is green, front passenger door trigger is lt. green/red, and the rear door trigger is green/white.
Dome Supervision comes on with unlock
Trunk/Hatch Pin red - factory alarm plug
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer blue test connector
Notes: It is a 2 pin plug to the passenger side of the battery.
Wait to start N/A
Brake Wire white/black + brake pedal switch
Parking Brake
Horn Trigger orange - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
dealseaker
01-08-2007, 04:59 PM
thankyou for that info, that is about what came with my instructions, the omega type C transponder data interface TYPE-C IB-H3 is the one I might have trouble with, when I plug the wire into the interface, where do I plug the other end into, or do I just use the wires that do not go to the other plug?
xproductionz
01-28-2007, 04:34 PM
Second Starter N/A
Second Ignition N/A
Third Ignition N/A
Hazards
Turn Signal(L)
Turn Signal(R)
Hood Pin N/A
Factory Alarm Arm
Disarm No Unlock
Wait to start N/A
Parking Brake
Memory Seat 1
Memory Seat 2
Memory Seat 3
what he said
BrodyP
01-28-2007, 07:56 PM
Thats so weird I went to your site today Mike when I was clicking through my Myspace bulletins. Nice forum you have there.
