95 grand am
redneckdad10405
01-06-2007, 06:55 AM
i have a 95 grand am i was wondering if anyone could help me on an easy way to flush the radiator cause im getting alot of rust out of the radiator
xeroinfinity
01-06-2007, 11:22 AM
Buy some radiator flush(probly two bottles since its rusty) and follow the directions.
You just run it for 20-30 mins then drain, refill to rinse several times.
Should be a drain on the bottom of the radiator. If its not or broken you can drain it through the lower radiator hoses.
Also wait til it coola down before you open the drain or loosen any hoses as you will get burnt. :yikes:
I'd say since its rusty that thier wasnt enough coolant in your system, so it rusted.
Be sure to use the correct coolant mix,
other wise you risk overheating and or if it froze it would break your motor or radiator. Thats no good :grinno:
Hope that helps.
Hope that helps.
