Transparent colour
D.E
01-03-2007, 10:29 AM
Hello. I went to the hobbystore to get some transparent orange and red, but it turned out that they didnt have any transparent red left. :banghead:
Is it possible to convert rattle can red paint to transparent brush colour? And also, can you tint it to get tinted taillights?
stevenoble
01-03-2007, 12:55 PM
I assume you are using the red paint to paint the tail-lights on your model? If so, I think you would be better off with the transparent red and not regular red paint from a spraycan which is not transparent so you will not get the desired effect on your tail-lights,as it is not see-through.To tint/smoke the lights you can use Tamiya X-19 Smoke which is basically a clear/see through smoke colour.You can build it up layer by layer until the desired effect is achieved.More coats makes it darker,less coats it will be lighter.
Flea
01-03-2007, 09:09 PM
you also can use fingernail polish .. most all of the time it is clear ... or take just a drop or two of a normal red and mix it with some clear paint to tint it .. and make your own red ...
or look for a paint that says it has a 'candy' finish ... typically those are just tinted clearcoats...
