heater issue..
FuLL BLown STD
12-27-2006, 02:47 PM
ok so if a heater suddenly stops working..what should i look for other then the heater motor fuse..91 dx
CivicSpoon
12-27-2006, 03:06 PM
any wet areas under the dash (heater core leaking), and see if your engine is overheating.
FuLL BLown STD
12-27-2006, 03:58 PM
a leaky heater core would keep the blower from working all together..? i will have to check..see this is why u dont sell a car to a friend :banghead: he like a brother tho but isnt mechanically inclined
johnb16a2
12-27-2006, 04:42 PM
Do you mean the heater fan doesn't work? If so, it's most likely you fan resistor is busted. It's located behind the glove box door and is avaiable at the dealer or easily available used at the junkyard (just make sure all the coils are intact).
CivicSpoon
12-27-2006, 06:24 PM
i assumed you ment that you're not getting heat anymore, didn't realize you ment blower.
hondacivic99sivtec
12-27-2006, 06:55 PM
hmmm check your grounds also.
Hybrid1990crx
12-27-2006, 09:04 PM
if the resistor goes bad the blower still works on the highest setting. this is a very common problem with g2 integras.
dustin what have I told you about asking questions on here? go to honda-tech!
hondacivic99sivtec
12-27-2006, 09:10 PM
oh we're not good enough?
just take it out. who needs a heater, that's what a coat is for.
