Is there a cure for heat/ac problems?
rc06
12-20-2006, 08:22 AM
I have a 99 Taurus se, only had it a couple of months. First the heat didnt work - air blows out but not hot. We replaced the temp control switch and flushed the heater core. Now I get heat but no a/c. Im about ready to take it too a shop to have it fixed but I dont want to spend 60 to 90 dollars an hour for someone to troubleshoot. and then pay more on top of that for them to maybe fix it.
I would greatly appreciate any help or advice. Thank you
MT-2500
12-20-2006, 08:35 AM
Auto or manual air?
If auto any body codes?
There is some TSB on blend door problems on some.
If you are going to fix it yourself.
I would suggest a All Data sub.
http://www.alldata.com/products/diy/index.html
And remember with auto controls you will need a good body capable scanner to check it out.
Auto or manual air?
rc06
12-20-2006, 10:37 AM
It is manual heat and a/c
I do have a subscription to alldatadiy.com.
Im female, but very willing to learn. I just need a bit more detail directions
Thanks
Thanks
shorod
12-20-2006, 09:32 PM
Does the A/C compressor engage and the cooling fans on the radiator run when you turn on the A/C?
Can you tell if the mixing door is moving that diverts air around or through the heater core at varying rates depending on the temp setting?
-Rod
-Rod
