Valve cover gasket
Dave_s
12-18-2006, 11:38 AM
I'm going to replace my valve cover gasket in an attempt to stem my loss of oil. Is this a difficult job for a DYI (I have done work on other cars, but not this before)? Any tips?
wrightz28
12-19-2006, 10:12 AM
What year?
Anyway the Toyota's I ve had so far have simplly been to remove the PCV hoses, them there are 3 nuts rignht on top of the cover (10mm ?) simply back those off and away she goes.
HeWhoKillz
12-19-2006, 03:45 PM
So if I go to do that to my 91 thats all I have to do?
wrightz28
12-19-2006, 04:29 PM
In a nutshell.
I'm don't know for sure on your 91, but my '89 has a wire loom over the upper timing belt cover that has to move a bit and plug wires if they are top mounted.
Twizted_Image
02-13-2007, 10:54 AM
yea the there a 10mm bolt and wire loom that goes over the cam gear, 3 bolts across the top, and its out. Check the condition of your spark plug tube gaskets located under the valve cover. Also i recommend checking the condition of the 3 valve cover gromets that are on top too.
wrightz28
02-13-2007, 11:51 AM
Last few I've done had the grommets included with the cover gasket as a 'set' from Felpro.
