94 shadow charging system
needsnewcar
12-03-2006, 02:02 AM
dose the shadow pcm regulate the charging?
Thanks
Thanks
jdl
12-03-2006, 01:16 PM
Yes, I believe it does. You didn't list an engine size. I don't guess it matters. A lot of chrysler vehicles regulate the charging system, that way.
I just wanted to add, on the back of the alternator, there should be three terminals coming out of a common bracket, the two wires or terminals that are parallel to each other, should be the field terminals, with the engine running, one should have B+ the other should have a dc pulse on it. The dc pulse shows the pcm is trying to regulate the voltage by switching the circuit on and off.
needsnewcar
12-03-2006, 07:43 PM
thanks for your answer.
I'm going to be installing two phoenixgold amps OCTANE-R 15.0:1 along with my pioneer amp, monitor, and xbox. into my neon.
I was thinking about installing a second charging system to run it. Have shadow parts kicking around, thats why i asked about the shadow. any ideas on what i could do would help.
G.m alternators come with a built in regulator?
Would i need to run a second charging system?
Mike.
Mike.
jdl
12-04-2006, 01:10 PM
Sorry, I'm not a stereo person. You could probably do a web search, and come-up with all kinds of info. There is a site. www.the12volt.com they have Q&A forums. If you don't find out anything here.
Yes, the GM alternator has an internal voltage regulator, at least the ones I fool with.
I don't know if your charging system will handle your set-up. the company you bought the equipment from, might have some advice on that.
