Cai
stanzz
11-30-2006, 05:37 PM
Does anyone know a good CAI manufacturer? I was looking on the K&N site, but it doesn't list an intake for a sunfire. Any suggestions?
PsychoJJ
11-30-2006, 06:28 PM
AEM, Injen, K&N, Weapon R, ebay craptech and Im sure cody will be along sooner or later to whore out his guys intakes so Ill let him sell you on that.
Also your better off looking for an intake for a cavalier with the same type of engine as the sunfire in question. Most places only list for cavaliers and assume people will know that a cav and a sunfire are about the same animal.
Classicrocjunkie
11-30-2006, 10:29 PM
2200 OHV CAI...
http://www.rdfabs.com/galleries/images/project_vehicles/2000_sunfire/summer_04_engine.JPG
2.4L CAI...
http://www.rdfabs.com/pageimages/24-caint1f.jpg
2.2L Ecotec
http://www.rdfabs.com/pageimages/22eco-caint1f.jpg
All intakes are made from T-304 Surgical grade stainless steel then hand polished to a mirror finish, unlike the aluminum ones every body else uses.
RDFABS - Stainless Specialists. (http://www.rdfabs.com/intakes.html)
stanzz
12-01-2006, 09:16 AM
Nope. Nothing for a Cavy either.
It's just that, If I buy a new intake, i want to have a good filter too.
I read that a good CAI will give me about 7-9 HP? Is this true for a 01 Sunfire 2.2?
Lances133
12-01-2006, 01:27 PM
No.
Classicrocjunkie
12-01-2006, 03:08 PM
We have an option to buy ours with K&N filters.
Lances133
12-03-2006, 12:06 PM
What are the benifits of stainless steel rather then aluminum? Isn't the SS alot heavier?
CavLCD128
12-04-2006, 02:18 PM
yes but its shiny...and u need shiny stuff so people forget its a cavalier lol
jk but im assuming it depreciates heat faster then aluminum...or it can withstand more heat....
MrR0b0t0
12-04-2006, 03:12 PM
No, aluminium loses heat faster, and is also lighter. SS is stronger, but heavier, and less heat loss.
Lances133
12-04-2006, 04:36 PM
So, a SS intake is actually not that great of an idea then?
matthewdaye
12-04-2006, 06:14 PM
I believe I read somewhere on the AEM site that with the 2.4L a short ram intake was just as effective as a CAI. That seems a little strange. Anyone else read this? I haven't seen many CAI's for the 2.4, but many SRI's, maybe there is some truth...
Classicrocjunkie
12-04-2006, 08:58 PM
Stainless properties info.. (http://www.rdfabs.com/techcenter.asp)
Lances133
12-04-2006, 09:23 PM
Does SS rust? No, right?
MrR0b0t0
12-05-2006, 08:17 PM
Not if takin care of. Its really hard to get it to rust, but its possible.
Classicrocjunkie
12-06-2006, 12:24 AM
Mine saw 2 winters. Not a single varnish spec on mine. I keep it clean tho. Thus while she still was like a mirror.
Lances133
12-06-2006, 02:21 AM
How could we arrange getting a bypass valve onto the rdfabs cai for the 2.4 cody? Could you just send it in pieces and then I just stick it in between 2 of the pipes? I would this work?
Classicrocjunkie
12-06-2006, 08:33 PM
It would come in 3 different sections, then 3 rubber couplers, filter and clamps. If you would like to use one of the bypass valves, just place it between the upper connection where we would supply you with a coupler, just use the bypass valve instead and use the clamps we provide. I am not running one becuase the only way you would hydrolock your engine would be if you go through a puddle thats 2 feet deep. If you can avoid those, you don't need the bypass valve.
Lances133
12-06-2006, 08:44 PM
Oh, I just figured any moisture wouldn't be good. Edit* actually now that I think about it, we've recently had 2 pretty bad rain storms that created some passives puddles from clogged road drains i guess so I think i'd definitely have to get a bypass just to be safe.
