transmission woes and only 77K miles
hgjacobsen
11-30-2006, 05:32 PM
My mom has a 1996(?) Sedan DeVille Concours. After a waterpump change, the transmission has acted up. When I drove it in 4th/Overdrive, it was fine at low speeds, but when I got up to that 4th gear, nothing but RPMS. It appears to drive fine in 3rd, but the RPMs are a bit high, due to not being in Overdrive. Her mechanic says the transmission does not go through all the gears an dwhen it gets to overdrive, nothing.
A transmission shop he recommened says that it would cost $1500.00 to "Fix" the problme but if teh discs are burnt, it would have to be rebuilt and will cost $2500.00-2800.00 to do it.
I researched the web and came across the "A" solenoid. Not sure what the function of the solenoid is, but I am assuming that it has something to do with shifting into 4th gear. And that it is buried in the transmission.
Any help would be great as my mom is on a limited income.
TIA,
Henry
TIA,
Henry
DFBonnett
11-30-2006, 06:21 PM
You need to research how to pull up the computer codes for the car. That will tell a lot.
maxwedge
11-30-2006, 07:20 PM
TIA,
Henry
Welcome to AF, in addition to DfBonnett's info the trans should be scanned on a trans function scanner to confirm shift solenoid operation and look for slippage error codes, this will point to the problem.
TIA,
Henry
hgjacobsen
11-30-2006, 09:05 PM
Thanks for the info, but took teh car to the Cadillac stealer. Estimated cost was $350.00 and they think it it the solenoid too. Actual mileage was 72K not 77K. Will keep you all informed. Thanks again.
hgjacobsen
12-01-2006, 07:21 PM
Yep, it was the solenoid, $337 plus tax to fix!
