RPM is too high
blu3honda
11-27-2006, 12:28 PM
Hi Guys,Need help please
My Honda civic 91 when temp is hot ( after i drove couple hours)the RPM is going to 1500
and sometimes i have to use hammer to knock a lit bit the Idle control
is this mean my Idle control is Bad ? or maybe they are something else that i have to search ?
Thanks a lot
turtlecrxsi
11-27-2006, 02:57 PM
Is your check engine light on? Are there any codes on your ecu (pull back passenger foot carpet and count blinks)? What do you mean by "sometimes i have to use hammer to knock a lit bit the Idle control"?
blu3honda
11-27-2006, 04:19 PM
check engine light is off
if the rpm is high .I mean i do " Tap " the idle control with hammer
and then it will be back to normal.
and i do not know about the ecu thing
I will look at it
Thanks
CRXperiment
11-27-2006, 06:16 PM
Check for vacuum leaks.
Try cleaning your IACV:
http://honda-tech.com/zerothread?id=1575913
If that doesnt work try your FITV:
http://honda-tech.com/zerothread?id=699787
blu3honda
11-28-2006, 11:03 AM
wow...that's so cool and nice Pic too
I will try it at home
Thank you...thank you...
I 'll let you know if it works
Thanks again
