Thermostat Location 96 grand am
Grand 96
11-22-2006, 07:03 PM
Where is the thermostat located on a 96 grand am because my car is running cold even with cardboard in the front and i realy need heat!
Please Help
xeroinfinity
11-22-2006, 10:13 PM
it would help to know the engine size. :grinyes:
Grand 96
11-23-2006, 12:30 PM
Sorry it is a 3.1L 6cl with and auto trans.
xeroinfinity
11-23-2006, 03:27 PM
It is Located under the throttle body area.
If you follow the top radiator hose(on the drivers side) it leads right down to it.
You will need to remove the air intake tube to get to it.
Might have to lossen or remove the exhaust crossover heat shield to get to the two bolts.
Pretty sure they are 13mm botls on the thermostat housing.
Heres a pic of that location, you 3.1 may look a little different but its in the same spot.
thermo housing (http://i28.photobucket.com/albums/c242/xeroinfinity/11X17RW24/thermohousing.jpg)
Grand 96
11-23-2006, 07:17 PM
Thanks alot i will check it out tonight and replace with a 195.
