code P0304 and 0175?
99'explorer
11-21-2006, 02:29 PM
I drove my explorer yesterday and sudennly the engine light came out. I went to check in Autozone and all i get was p0304 and p0175. What should i do? should i change sparks plug or wire? or?
shorod
11-21-2006, 05:22 PM
What engine does your 1999 Explorer have?
Since code P0175 corresponds to system too rich (bank 2), I suspect you have a V-6.
The P0304 code points to an engine misfire detected on cylinder #4. It could be plug wire, it could be spark plug, it could be fuel injector, and possibly a couple of other things. This code is likely the cause of the P0175 code.
When was the last time you performed a tune-up on the Explorer?
-Rod
-Rod
99'explorer
11-21-2006, 06:10 PM
I just bought it a week ago. Yup, is a 4.0 v6 sohc. Could it be the fan belt or timing belt cause it?
shorod
11-21-2006, 10:07 PM
I cannot think of any way either of the belts would be likely to cause it. If the timing belt were stretched, there would be other symptoms. Stick with teh basics first, such as the plugs, plug wires, and throw a bottle of fuel injector cleaner in the fuel tank for good measure.
Is there a reason you ask if one of the belts could be the cause?
-Rod
-Rod
99'explorer
11-22-2006, 12:15 AM
Not really but the previous owner told me to change it soon. The mileage of this is 136k so i will think of any possibilities that cause the problem.
99'explorer
11-23-2006, 11:44 AM
I have my plug change and disconnect my batteries. The engine does not come on again. Thanks guy
