94 Shadow 3.0 V6 Stalling/Stumbling
chaley
11-21-2006, 04:41 AM
Hi,
My daughter has a 94 Shadow with a 3.0 V6. The car stumble and sometime stalls. The Tach will turn on and off as the engine stalls/stumbles. Had the car on a diagnostic scanner and everything checks out OK.
Would the distributor pick up sensor cause this problem? The MAP and TPS have been replaced by a mechanic with no change. I believe I am dealing with a bad wire issue. Anybody had this problem or have any insight?
Thanks,
CH
dylanger
02-10-2007, 05:52 AM
how are the plugs? it could be the distributer.
my 92 with a 2.5 in has the same problems.
it sounds as if it could be missing.
I had a half assed mechanic that didnt screw down a plug all the way and well It looked like NASA, check the distributer and plugs. try wires too.
