little heat?
Seachelle
11-20-2006, 09:34 AM
Now that we are getting cooler weather I am noticing it more... Inside my car I have a heat dial 1-5 and 1-2 blow out nothing 3,4,5 blow very little and not to hot either, does anyone know what is causing this, my car is a 2000 Malibu, is this a common thing that happens? Temps are gonna get pretty cold this week and need to get this fixed. Thanks guys :)
Seachelle
11-20-2006, 10:32 AM
I called around and found out it is my fan switch relay so I am gonna go get it fixed, thanks anyway. :rolleyes:
Polishpat
11-20-2006, 08:09 PM
Same car, same problem today, but the heat kicked in a few hours later, so ill just keep my fingers crossed
DRAGONRACER76
02-01-2007, 02:53 PM
one other possibility is a clogged heater core, usually caused from gunk in the coolant system building up. luckily it can usually be corrected by doing a "coolant system flush" (not just the radiator) remembering to leave the heater in the on position.
Johnny R
02-02-2007, 02:50 PM
With my 99 Malibu, the fan speed problem was the female plug on the blower motor. I lucked onto that by wiggling the wiring harness in the area of the connector. I replaced the motor and everything is fine. It was definitely not a resistor card problem.
Negatoro
02-04-2007, 08:05 PM
Johnny,
In the past couple of days I had a problem with my blower motor cutting out and/or sputtering. It would go from blowing full force to limited/no output.
I wiggled the harness and got some response from the motor.
I observed that if I pulled back or pushed forward on the connector the motor would run normally.
BUT - the problem wasn't the female plug.
There was a fault somewhere within the motor unit, between the motor and connector for the 12v feed. I temp. fixed this by pulling the connector back and shimming it up with a piece of popsicle stick.
It's too bad you can't service these units.
I'll get a new motor soon. One more thing to add to the junkyard shopping list.
-Mark T.
Johnny,
-Mark T.
Johnny R
02-05-2007, 09:22 AM
Yeah, I used the popsicle stick too. That worked for 2 days then quit. So I pulled the connector towards the motor and held the tension with a cable tie. That lasted a couple of days, then quit too. There was too much blood rushing to my head when I'm laying upside down under the dash fiddling with this :) so I broke down and installed a new motor. No further problems.
Negatoro
02-05-2007, 11:17 PM
I'll say again, 'It's too bad you can't service these parts.'
My popsicle stick fix is holding up two days so far with the motor on high all the time [~5*F and I'm missing a rear quarter window]. My numb fingers and twisted back were cursing me for a few minutes today as I replaced the resistor [getting the screw back in on the firewall side is a major PITA!]. I used ACD# 15-8966; Hopefully the new Delco part outlives the car. The motor is now powered 1,2, and 3.
If the popsicle stick fix fails then I think I'm going to try neatly cutting the connector off and repairing that connection if it's accessible. If that fails I'll be able to justify buying a new motor.
-Mark T.
-Mark T.
