93 Suburban Tranny and fuel pump question
spudspuppy
11-19-2006, 02:59 PM
Hi,
I have a 93 Sub 1500 w/L60E transmission with 180k miles. Recently changed fluid and filter and discovered 3 or 4 pieces of metal that look like broken rings (about a 1/4" in diameter) in the bottom of the pan. Fluid was not particularly dark and I used Dexron III to refill. Transmission still shifts fine but I'm a little concerned as to what these rings are. I'm about to embark on a 2500 mile trip and I'm not sure if I should put my trust in it.
Also, I recently changed the fuel pump. I have noticed that sometimes it won't crank on the first try. However, once it starts, it runs fine. Could it be that I'm losing pressure in the line or is there something wrong with the pump. It seems to be an itermittent problem as it does not occur all the time. I would guess that if the fuel pump were faulty it wouldn't run properly down the road.
Thanks for your suggestions.
LarryG
LarryG
spudspuppy
11-19-2006, 04:12 PM
Amendment: The rings are close to 1/2" in diameter and have a twist to them as if they used to be part of a spring. However, the metal is very hard and you can't deflect it by hand. Hope this helps...
LarryG
LarryG
spudspuppy
11-26-2006, 02:01 PM
Does anyone have any ideas as to what those metal rings are?
Thanks,
LarryG
Thanks,
LarryG
maxwedge
11-26-2006, 04:24 PM
Sounds like clutch return springs, but I can't see them getting out of the clutch drum, no pics?
spudspuppy
11-26-2006, 04:54 PM
Hi Maxwedge,
I've attached a few pics for your reference. Does this help? Disregard the paint on them as my daughter managed to spill some on them in my shop
Thanks,
Larryg
http://www.jinksstudio.com/larryspage.html (http://www.jinksstudio.com/larryspage.html)
Thanks,
Larryg
maxwedge
11-26-2006, 06:52 PM
Yeah they look like clutch springs This can definitely cause issues down the road with slow clutch release.. I'd take them to a trans shop to confirm my suggestion.
spudspuppy
11-26-2006, 07:03 PM
Hi Maxwedge,
Thanks for the suggestion. I will check it out. I don't suppose you have any thoughts on the fuel pump issue?
Thanks,
LarryG
Thanks,
LarryG
maxwedge
11-26-2006, 07:05 PM
Only way to eliminate the fp is to see if the 2 second prime works, if so then you would have to check the fp after the prime event.
