| Search | Car Forums | Gallery | Articles | Helper | Air Dried Fresh Beef Dog Food | IgorSushko.com | Corporate |
| Exterior | bodykits | Lighting When your ready to showoff that 'H' ride, here's your forum! |
Show Printable Version |
Subscribe to this Thread
Thread Tools |
High Beam/Low Beam Problems
I just intalled some new Generation II housings on my 99 civic. I got them in fine, but when testing out to see if all the lights worked, I found out that the running lights/turn signals and the high beams worked fine, but my low beams don't. I first thought that the low beam bulbs were burned out, but after swithching some wires I found that both sets of bulbs worked fine, just that the ones connected with the low beam wires didn't work. Then I thought that maybe it was just the new projector set, so I put the originals back in, but the same problem. I'm not sure if the new housings caused the problem, or if my low beams just have not been working for a while (I haven't been doing much night driving lately). So basically, my question is if anybody else has had this problem, or if anybody knows what's causing it, and possibly how to fix the problem. I really don't want to go to a mechanic, only as a last resort.
check the headlight fuse for the low beams, maybe you shorted the system when you installed the new bulbs, that fuse is either under your dash or in the engine fuse box.
Name: Scott Stable Of Cars I have Owned: 1991 Honda CRX 1990 Oldsmobile Cutlass Supreme 2003 Honda Accord 1998 Chrysler Concorde 2007 Honda Civic 1997 Toyota Camry 1995 Saturn SC2 1996 Ford Taurus 1991 GMC Sierra 2002 Daewoo Leganza 1999 Dodge Ram 2007 Honda CR-V 2003 BMW 325i |
Good call. I don't know why I didn't think of it earlier. Sure enough, both fuses were blown, so it was an easy fix. Thanks.
Damn. After replacing the fuses, my low beams worked when I checked them, but this morning went I went out and turned them on (it was raining), both were out again. I checked the fuses again, and both were blown. I'm starting to think that the new bulbs have an incorrect wattage for my lighting system. Would new headlights that match my original low beam wattage work? If not, any other suggestions would be greatly appreciated.
POST REPLY TO THIS THREAD |
