1994 passport rear size?
ishondau
11-17-2006, 07:58 PM
recently obtained a 94 passport lx 4x4 3.2 tackled the timing belt job now its the rear axle bearing and most likely the shaft judging by the noise it makes my question is what size rear is on this vehicle? ive noticed on auto parts sites theirs two listings for bearings coned or sealed? basically i need to replace the rear wheel bearing and axle shaft just dont know what the rear is dana44? any help is appreciated.
Ramblin Fever
11-17-2006, 08:52 PM
My '97 is a Dana44
My '91 was a chevy 10-bolt - IIRC
ishondau
11-17-2006, 09:32 PM
ramblin thanks for replying. whats the difference between the chevy 10 bolt and dana44? does the dana also have 10 bolts? is their a way to tell by looking at it?
Gizmo42
11-17-2006, 11:10 PM
I didnt think isuzu used GM axles. I think it was an isuzu 10 bolt.
Easy way to tell the isuzu axle from the d44 is to look at the back of it. If it has a removable cover its a d44, if it doesnt its either an isuzu 10 bolt or 12 bolt (dunno if they used 12 bolts on rodeos).
surferfletch
11-17-2006, 11:12 PM
I had a good link for that info...
Ramblin Fever
11-17-2006, 11:22 PM
Both my Rodeo's had removable covers - towed the boat a lot with both, fluid got changed quite a bit.
Could be wrong, but I'm pretty sure that '91 had the GM-10 bolt, had a GM 3.1L Chevy engine too - not that that has anything to do with, just thought it was funny back then to have an "Isuzu" with a GM engine, drivetrain, and rear-end.
I know for certainty, without a doubt, my '97 has the Dana44.
What they used between those years, was a combination of the two, I'm sure - BUT, I don't know what years got what.
surferfletch
http://www.powertrax.com/isuzulr.pdf
Gizmo42
11-17-2006, 11:44 PM
Guess I was wrong (yeah it happens once or twice a year :lol:
Here is a list from Matts (indy4x) faq on his site..
WHAT AXLES DO I HAVE IN MY TRUCK? ISUZU AXLE INFORMATION LIST
TROOPER
STOCK RATIO: 4.56:1 EXCEPT W/ WIDE TIRE OPTION 4.77:1
1985-86 4WD 2.3L 4CYL
FRONT: ISUZU IFS 8 BOLT (SOMETIMES REFERED TO AS 9 BOLT)
REAR: ISUZU 10 BOLT (3RD MEMBER, DRUM BRAKE)
1987 4WD 2.3L 4CYL
FRONT: ISUZU IFS 8 BOLT (OR)
ISUZU IFS 10 BOLT
(NOTE: SOME SPLIT YEAR -SOME END OF YEAR MODELS HAD 12 BOLTS)
1988-91 4WD GM 2.8L V-6, 2.6L 4 CYL
FRONT: ISUZU IFS 10 BOLT
REAR: ISUZU 12 BOLT (3RD MEMBER, DISK BRAKE)
1992-97 4WD 3.2L 6 CYL
98-2002 4WD 3.5L 6 CYL
FRONT: MODIFIED ISUZU IFS 10 BOLT
REAR: MODIFIED ISUZU 12 BOLT – LARGER OVERALL, DANA RING
GEAR ALMOST IDENTICAL TO D60 (3RD MEMBER, DISK BRAKE)
AMIGO
1989-1994 2.6L 4 CYL
REAR: ISUZU 12 BOLT (3RD MEMBER, DISK BRAKE) (4WD & 2WD XS)
REAR: 2WD NON XS MODEL – ISUZU 10 BOLT
PICK UPS
1988+
RODEO
1991-92 GM 3.1L V-6, 1993-94 4 CYL.
REAR: GM 10 BOLT (DRUM BRAKE)
RODEO/ HONDA PASSPORT
1993-4 V-6, 1995-97
REAR: DANA 44 (DISK BREAK, USES 4.10 RING GEAR ON 3.92 DOWN
SMALL CARRIER – THICKER THAN STANDARD RING GEAR)
1998-2001 3.2L 6 CYL
FRONT: ISUZU MODIFIED IFS 10 BOLT ( LIKE TROOPER)
REAR: DANA 44 ( SLIGHTLY MODIFIED, FINNED COVER 4.10 STOCK)
ishondau
11-18-2006, 02:34 PM
thanks guys info helped its a dana44. also what sealant should i use on the cover since i didnt see any gaskets listed on parts sites.
Gizmo42
11-18-2006, 04:42 PM
I tried just a paper gasket and it leaked. Any paper gasket for a D44 will fit, but the surface of the diff isnt very smooth so the paper one wont seal well. This time I used a paper gasket with a light coat of old school red RTV on it and seems to be holding well. Any of the Permatex Ultra RTVs should work just fine without the paper gasket. I'm hoping that the paper one helps it come apart easier next time, but I dont know.
surferfletch
11-18-2006, 11:14 PM
I use straight black Permatex RTV. The red has worked just as well for me, too.
ishondau
11-19-2006, 05:53 PM
thanks again guys i just picked up the bearing kit and rtv now i just need to rip it apart and hope it dont need an axle also any advice on which oil or additive to use for loud lifters ive read some threads saw one that said use 1 qt of atf and 10w30 any tried and proven methods right know its loaded with 5w30 and 1qt risselone didnt work. sorry guys newbie search threads going to try ramblins theory to cure this tick wish me luck later
