Replacing Front Brakes
medicmandan
11-17-2006, 05:25 PM
And I'm probably doing the whole deal. I haven't measured the rotors yet to see if they can be turned again. I'm hoping so just to save some money on the project.
I was shopping online for new calipers and I found some remanufactured ones. I found several that are listed as "unloaded". What does this mean?
shorod
11-17-2006, 05:33 PM
"Unloaded" means they do not come with brake pads installed. You will need to buy brake pads separately.
-Rod
medicmandan
11-17-2006, 05:34 PM
-Rod
That makes sense. What is the difference then between semi and loaded?
shorod
11-17-2006, 09:13 PM
Hmmm, I'm not sure what semi-loaded would be. Maybe it comes with new mounting hardware, but not the pads? Just guessing there. Does the online site selling the semi-loaded calipers have contact information?
-Rod
MyTaurus8AChevy
11-18-2006, 10:10 AM
Loaded calipers come with everything you need in one box, including the brake pads. Not only do you get new brake pads, but also a professionally rebuilt caliper and properly matched hardware (shims, bushings, slides, etc.).
Semi-loaded calipers come with a rebuilt caliper and properly matched hardware (shims, bushings, slides, etc.) except for the pads themselves :) I prefer semi-loaded because I am very particular about the pads that I use (TRW ceramic). Loaded calipers are less of a hassel because everything comes in one box, but you may not like everything that comes in that one box. It's 6 of one, a half dozen of another :p
KimMG
11-19-2006, 03:24 AM
Check out your local chain auto parts stores. You maybe able to find rotors for less than $30 each.
mwt878991
11-19-2006, 05:58 AM
one year AZ rotors are 21.99 for 2001 and above and 17.99 for 2000 and under.
I am changing mine this weekend. They had over 50K on the front using the Duralast Ceramic pads and the one year warranty rotors.
Mike
:smokin:
Willyum
11-19-2006, 02:00 PM
Why replace the calipers? The pads too difficult to install?
