TCS Switch
KJRich
11-12-2006, 12:54 AM
I just noticed today that the little light that glows in the TCS switch is not on anymore, and it doesn't matter if you toggle the switch, there's no way to know if its on or off. I know it should be on by default, so I guess my question is this:
Does this mean my TCS system in inoperable, or has the bulb burned out? Any ideas? Is there a fuse for the TCS system?
GregA
11-12-2006, 01:16 AM
Could be a bulb, could be a fuse. I believe it is fuse # 31 near the top of this page (Fuses) (http://www.my-chevy-venture.com/fuses.html), at least for a 2001. I'm not sure if it matches a 1999, but at least its a starting point.
Take Care,
'97ventureowner
11-12-2006, 11:22 AM
Check and make sure all your rear lights are operational. I noticed when my TCS light used to be out, one or more lights on the rear of the vehicle were out. This was before I replaced the boards in the back to correct the problem. This could be a sign that your boards may be starting to develop a problem.
KJRich
11-15-2006, 08:07 AM
Thanks guys. I will look into it. I do know that my rear lights are all working, though.
amitnf
02-04-2007, 01:26 PM
So what was the solution to this problem? I'm having the same problem but don't know where to start to get to the bulb.
