| Search | Car Forums | Gallery | Articles | Helper | Air Dried Fresh Beef Dog Food | IgorSushko.com | Corporate |
Idling promblems what else is knew?
Idling promblems have seem to become a usual with Marquis especially late 80's and early '90s. I wonder why Ford never fixed this promblem, I know many Marquis owners including myself with this promblem.
My idle promblem: First of all I've had this promblem for as long as I owned my '90 Merc 2 1/2 years, and like many others it's a sproadic promblem, occuring roughly once or twice a month. And usually when it happens it'll stalls 2 or 3 times and thats it. I've had my mechanic replace the EGR valve (2 yrs ago) among other things. Nothing. Anyone, suggestions? I love Marquis, otherwise a wonderful, enjoyable, reliable car. THANKS |
Re: Idling promblems what else is knew?
Any clues as to what might be the problem. Grand Marquis is not new for me, but the problem is new
It is possibly the idle air control (IAC) valve or a mass air flow (MAF) sensor. What are the symtoms? Does it idle rough? Do the RPMs go up and down while it's idling?
Thanks for your response!
The car works perfect, no rough idle at all. The problem is very sporadic and it usually dies when going slow and on a bumpy road. It is more frequent when the car is warm (after running in the highway), but it has happenned also right after I leave home (couple blocks). I has failed also making u-turns a couple of times. The car just dies, and I can easily turn it back on either in N or P - no problem. Any ideas? Thanks! |
It could be a number of things. At first pass, it doesn't sound like an idling problem. Has your mileage dropped off as well?
It could be an ignition module problem. The TFI ignition module is on the side of the distributor. They fail sporadically sometimes and often misbehave when they get hot. It's a common failure item (my Dad's '86 Mustang is on it's 3rd module and it only has about 65K miles). If you decide to replace it, use Ford/Motorcraft part. The aftermarket parts are just not as good and don't last as long. You can get the genuine Ford part on-line for less than what you woul pay at a dealership. You might also check and clean all the electrical connections (MAF sensor, IAT sensor, O2 sensor, etc.). A bad connection *might* cause the problem as well. |
Thanks for the response!
Question: My car is a 98 (no distributor). I guess it does not have a TFI ignition module. Am I correct? Sorry for the question. I am not a mechanic. On the other hand, mileage is just fine. No problems ther than it dies every once in a while. It seems that lately it is failing more when I am turning right (especially u turns). I have the impression that the problem is related to gas pump or tank. Wil ltry cleaning the connectors for now. Thanks again. |
Sorry, I meant turning left.
I had problems with a 1984 T-B 5.0L and the vacuum port for the egr & ect was plugged solid I had to take it off and use a small screwdriver to clean it out.
I also had problems with the wiring harness. It had a bad wire between the pip in the dist and computer. I also had a loose ground wire by the computer for the eec. relay. Otherwise it was modules and ignition switch which dropped the voltage to the module. The fuel pump relay went out at 135,000 |
Thank you. I will take any advice at this point.
Any ideas why the problem replicates when turning left? |
My son had the same problem on left turns with his 5.0L T-B and it was the battery sliding on turns. I forget exactly what happened but he asked me about clamping it down. As I was going to the junk yard for something else I looked his battery over and found something that would work. He was studying to be an electrical engineer and knew what he was talking about.
This fixed the problem |
POST REPLY TO THIS THREAD |
