1998 Rodeo Eng Knocking at Idle
sal111865
11-11-2006, 12:12 AM
Ok, I bought this 98 Rodeo 3.2 from a guy at work for $1500. He didn't want to deal with it. It has a bad eng knock at Idle and all rpm's.
It has 110,000 miles.
When I tore her apart everything looked fine. I went ahead and changed everything.
So I changed the water pump, tensioner pulley, tensioner, timing belt, serpentine belt.
I started her up and same thing. Knocking sound at Idle and all rpm's.
I'm thinking a spun bearing or EGR.
Which way should I go????
rodeo02
11-11-2006, 02:32 AM
If you have not addressed the bottom end yet, he probably ran it low on oil and you have a cooked #1 bearing. Pull the oil pan and look for shavings.
Joel
sal111865
12-02-2006, 07:43 PM
Well I removed the oil pan and found metal shavings and a spun # 1 rod bearing.
What would cause the # 1 bearing to spin? all the other bearings are fine.
Low oil from the previous owner???
Looks like I need to get the crank turned down and new bearing.
Does anybody know were I can get a 1998 factory shop manual? I already have a haynes manual.
trooperbc
12-02-2006, 08:44 PM
isuzu factory workshop manuals at
www.helminc.com (http://www.helminc.com)
sal111865
12-08-2006, 10:41 PM
I just got back with the machine shop guys they are saying the engine is shot. The block is cracked.
So now I'm looking for a long block for a 1998 Isuzu Rodeo 3.2 Manual transmission, 4X4
Any ideas were I can get one??? I live in Ogden, Utah
