bolt pattern on the 2000 mustang v6?
Underground_Killah
11-10-2006, 03:18 PM
Does anyone know the bolt pattern on my car? reason being i have some 17" enkei wheels that i put on my Infiniti J30t that i want to transfer over and am unsure if they will work.
TheStang00
11-10-2006, 04:00 PM
bolt pattern is 5-114
according to tirerack.com, the j30 also has 5-114 so it should work.
Underground_Killah
11-10-2006, 05:57 PM
You know Ts, you've got to be the best person on these forums. every question i've had you've answered. You are definately getting an award come december. thanks so much, i'll find out tomorrow. the reason being is these stock wheels are badly bent and i don't trust them... i don't have the money right now to buy new wheels and i can't afford to not do something about it. thanks so much again. cross your fingers, i hope this works
SkylineUSA
11-10-2006, 06:17 PM
Check the off set! Its not all about the bolt pattern:D
TheStang00
11-10-2006, 06:21 PM
:lol: i do what i can... that sucks about the wheels though. hope they work.
just out of curiosity, are the bent wheels these ones, or are they the five bar ones?
http://i21.ebayimg.com/05/i/08/08/b2/dd_1.JPG
Underground_Killah
11-11-2006, 12:09 AM
six bars, looks just like that one but in much worse shape.
Underground_Killah
11-11-2006, 12:12 AM
what's the offset for both cars then? :)
TheStang00
11-11-2006, 12:14 AM
i was just wondering cause thats what my car has too. mine are fine though. they are made of alloy.
SkylineUSA
11-11-2006, 03:09 AM
That is something you will have to check:smokin:
BlackGT2000
11-11-2006, 07:06 AM
Here is how to check the offset. Lay your wheel face down, so you are looking at the side you would normally not see. Than lay something straight across the wheel, such as a yard stick, but anything straight will do. Than measure the distance between the yard stick and the bolt holes. If they are the same than you are good to go, if the new ones have a larger offset than the tires will recess under the fender well even farther and if the new offset is smaller than the wheels will stick out too far and look really ghetto.
SkylineUSA
11-11-2006, 10:15 AM
That is back spacing, not off set. Off set is measured from the center of the rim, but back spacing will work as well :)
351wStang
11-11-2006, 10:30 AM
Get'm Tony! LOL another think on the b/s is ifyou have too much your tires will rub the inner fenderwell.
Underground_Killah
11-11-2006, 11:43 AM
they wobble.... unfortunate.
there's a place downtown that will let me trade in the old infiniti wheels (the wheels i'm selling online) as well as the mustang ones for some mach 1 wheels (if they still have them)
:crosses fingers: i'll find out friday!
BlackGT2000
11-11-2006, 11:03 PM
I guess I never pondered the difference and thought them to be the same thing.
