94 cougar v8 smoke? gas smell? shaking? loss of power?
markski037
10-31-2006, 08:45 PM
ello, i have a 1994 Cougar 4.6 V8, i started up my car this morning and there was alot of whitish-bluish smoke comming out of my exhaust. when i started driving it i noticed the car is shaking every time i accelerate and a major loss of power. there is a really bad gas smell coming from under the hood, and out the exhaust. im thinking it might be the spark plugs - but i had all 8 replaced back in june. any ideas please help?????
rhandwor
10-31-2006, 10:12 PM
Check the fuel pressure regulator on the fuel rail. Pull the vacuum hose and check if it is leaking. If leaking replace with a new one. Next use a flashlight and check for any leaks at the injectors. You can buy new o-ring sets if leaking. Then check the fuel pressure with a gage if both of the previous test are satisfactory. You can also check vacuum canisters for leaks. Look for leaks on the fuel line.
JR Tigerstar
11-01-2006, 04:22 PM
Try cleaning your MAF sensor wires ....
Cleaning MAF's sensor wires (http://www.tccoa.com/articles/intake/mafclean.html)
markski037
11-01-2006, 11:20 PM
yeah i drove the car today to work, i think something shot inside the engine and now is ratling when i start the car. i left it on the side of the street gonna tow it tommorow.
cougar4life
11-02-2006, 05:47 AM
Blue smoke is a sign of oil getting into the combustion chamber. This oil can foul the plugs and cause a misfire. This misfire could cause a fuel smell because that cylinder isn't firing and dumping fuel into the exhaust. I would start by pulling each one of the plugs one at a time and check them for oil or for anything else abnormal.
