charging problem
civic_boy91
10-24-2006, 10:06 PM
alright i have looked over alot of stuff, i have the d15b vtec witha pr3 ecu (i know b16a ecu...) with a s-afcII for tuning
the problem is when i put this motor and ecu in (wired up vtec)
the car only charges at 12volts till i hit vtec... than it go's to 13-14 volts like it used to with the old motor and ecu... it used to be at 13-14 volts all the time when the car was runing.
the only thing i havnt done is un wire vtec and put the pm6 back in.
im going to try that tomarrow and see what happens.
i had to jump start the car today...so this is a problem i need to deal with soon.
hondacivic99sivtec
10-24-2006, 10:35 PM
not really sure but check your grounds.
Hybrid1990crx
10-24-2006, 11:12 PM
i would say get the alternator tested. if you havent messed with any of the wiring between the battery and alt then that would be my first place to check.
civic_boy91
10-26-2006, 08:41 AM
alright thanks, i guess i will go over it again.
