Can ecm be checked?
micker
10-24-2006, 08:28 PM
Was wondering about how to check Ecm cause my tps is working good but Ecm says no it's not.
Thanks for responding
Whoaru99
10-25-2006, 07:39 AM
How would you know that?
Blue Bowtie
10-26-2006, 08:06 AM
Does the TPS have the proper 5V reference supply across the outer two terminals?
NoLiMiT06
10-26-2006, 05:10 PM
I was told there is no way to test the ECM, one thing you could do if you have is goto Firestone and let them run a diagnostic on it $80 and they should tell what's wrong if anything.
BTW I don't think your car wouyld run without the ECM. :)
Whoaru99
10-26-2006, 05:21 PM
And does the signal wire send out a variable output?
It may all work fine at the TPS (if 5Vref is good at the TPS, then it's pretty much guaranteed those wires from the ECM are OK) but the signal wire could be damaged/broken anywhere between the TPS sensor and the ECM input. Signal could test fine at the TPS but not be making back to the ECM.
Nosubsforcubes
11-27-2006, 11:27 AM
My mom's Buick has the same issue, signal seems good up to ECM. I decided to get an ECM, it's in the mail (at $55, it was cheaper than burning the car for insurance claims). What did you do to fix yours?
Thanks!
