its cold need heat.
indymajor
10-17-2006, 02:11 PM
ive replaced the resistor and checked the motor. after plugging the new resistor in nothing changed. i then pulled the blower motor and bench tested it. it was fine. i then checked all the fuses under the hood and in the dash all tested fine. not sure were to go from here. maybe the switch, i dont know. please help if you have any suggestions. i have also now checked the plug at the blower motor for voltage. it has none. once again: new resistor, all fuses are good, blower motor is good, but no voltage at plug. can it only be the switch in the dash or maybe relays under the hood.
xeroinfinity
10-17-2006, 10:11 PM
thiers a relay under the hood,
not sure which one but th elid has a diagram list :thumbsup:
double chekc your connections also !
