2001 Chevy Venture will not start
pamvi
10-15-2006, 02:54 PM
Good Day,
my 2001 Chevy Venture will not start. Everything works perfectly. all the lights, windows, automatic door, everything. When I turn the key, nothing happens. It is just quiet. I just got a new battery. It has been maintained on a regular basis. It has done this before. We will try to start it. It is totally non-responsive, and then we can go out 10 minutes later, and it will start like nothing had happened. This time it is not starting. After reading the manual, I just keep thinking it might have to do with the coded key, and perhaps it is shutting itself down. Is that possible? We are no longer under a warrantee, so we are taking our car to a qualified local mechanic that goes at least twice a year to classes in the states to keep updated on all the latest things. Unfortunately he is off island right now, and we are sitting here with a car that is on strike!!!
If you could help me or even let me know if you have heard of this problem before I would appreciate it. I have been reading and reading a lot of threads, and I have not come across one here that has mentioned the same problem.
Thank you.
truc0011
10-19-2006, 03:34 PM
Good Day,
Thank you.
A key issue usually also turns on the security light, it could be the starter or connection to the starter.
markqc
10-19-2006, 04:19 PM
Have you tried a battery boost? You said the battery is new. How new? It is common on these batteries to have a positive terminal corroded to the point where the post falls off the battery. If the cable was not cleaned properly you may not have a good connection. Also, you may have a bad ground connection.
Good luck.
Mark
tucker_707
10-20-2006, 07:01 PM
I did have the same thing with my 2001 venture when I first got it. On the message display in the dash when you turn the key does it show a picture of a lock (or similar) if so it is the key. I went through the same thing, picked up the van (new to us) and my wife's key would work but not mine. When I talked to the dealer he mentioned that sometimes when the battery is disconnected the code gets lost or change. You might just need to have your codes reprogrammed.
fanta2
10-31-2006, 08:52 AM
Have you confirmed your fuel pump is working correctly? When you turn the key "ON", you should hear the fuel pump hum a bit, pumping fuel. My 99 Venture wouldn't start, and it ended up being part of the wiring harnes that runs to the fuel pump. There's a connector in the floor behind the drivers seat that goes to the fuel pump. This connector was all corroded, causing my fuel pump to not work.
