Fuel Tank Question
Civic Jim
10-15-2006, 12:59 PM
Hi guys,
I am now swapping my D14 engine in my 4 door for the D16A9 out of a hatch
my question is are the tanks a straight swap between the hatches and the sedans , as my D14 is a carb i need to run a fuel pump from my original tank if they are different :(
thanks in advance
Jim
johnb16a2
10-15-2006, 01:14 PM
Hi Jim,
Yeah, looks like they are different but my tank swap knowledgebase is very limited. However perhaps you can retrofit the guts of the EFI hatch tank (pump, sender unit, etc) into the sedan tank? Anyone else? Please keep us posted. GL
Civic Jim
10-15-2006, 01:21 PM
thanks for the idea John i will bear that in mind when i get the tank off to have a look,
any more ideas peeps?
TheSilentChamber
10-15-2006, 08:44 PM
I believe the tanks are differt, but the sending unit/pump should swap out. if not you can allways just install an aftermarket fuel pump.
