which 350z is fastest of all???
wck73
09-05-2002, 04:56 PM
I was wonderin which 350z is fastest of all???
is track or base??? i don't think base is fast, because it doesn't have LSD. than is enthuasist the fastest??? someone please tell me!!!!!!!!?????:cool:
Ophitoxaemia
09-20-2002, 10:53 AM
since the motors are the same, the fastest acceleration will be based on traction and weight. i think i read the 18" wheels are lighter than the 17"? but you can buy even lighter ones than that and get better tires. however in practice i doubt you could tell the difference unless you stripped the interior.
-james
digerydingo
09-20-2002, 03:07 PM
Actually the Track Package drops 40lbs off the base package, probably the cheap stereo, no DVD Navigation system and lighter wheels. It's coefficient of drag is also a little lower at .29 instead of .30.
Translation: On the dragstrip the track package would be able to launch a bit better and finish maybe a half car length ahead thanks to the LSD and weight. On a road course the options would ad up to about half a second a lap thanks again to the LSD, weight, spoilers and also 18' Volks. And if you lived in Germany and felt like taking your car up to max speed maybe 7-10mph faster thanks to lower drag.
zane11
09-20-2002, 04:21 PM
Track because of lsd
tomlong
09-27-2002, 10:41 PM
If you take a model with LSD and put light 17 inch wheels on it as opposed to the 18's you will have shorter gearing which will make the car faster.
Stangduo
10-02-2002, 10:34 AM
Can you get the LSD as a option on the base model?
hokie350
10-02-2002, 12:15 PM
Yes you can, it's called the enthusiast model. ;-)
