Need Switched +12V in trunk of 04' .... ???
jfl330
10-10-2006, 08:19 AM
I need a swithced power lead in the trunk of my 04' Sable.
The wagons have a power antenna lead that would be perfect, but the sedans don't have this.
Does anyone have the pin out for the RCU unit? Perhaps there is a switched lead (besides the hot always lead) from the dash control unit.
Help is greatly appreciated !!!
shorod
10-10-2006, 01:10 PM
I can e-mail you a copy of the pinout for the ICU in the 2002. I would expect that your 2004 is similar. Do you have a test light or multimeter to confirm you got the correct lead?
Also, what are you intending to use this switched lead for? These circuits are fuse protected for a reason. If you attempt to draw too much current, you'll be popping fuses.
If you'd like a copy of the 2002 pinout, send me a private message with your request and an e-mail address for you that can accept PDF attachments.
-Rod
jfl330
10-10-2006, 01:22 PM
-Rod
Rod -
Check your pm.
Jon
way2old
10-14-2006, 08:44 PM
Do you have power trunk lock?
