bosche spark plugs
newfiejeff
10-10-2006, 08:53 AM
I have just replaced my front 3 spark plugs about a month ago, never had the nerve to do the back ones yet. Over the past couple of days ago the engine worked fine shut the engine off and then started again and there was a like to me a dead cylinder and the check engine light blinking. I have used bosche plugs on the front but have read that bosch plugs will cause problems. Will I change the back 3 first or put original ones back in the front?
Any thoughts
Jeff
Any thoughts
Jeff
maxwedge
10-10-2006, 09:48 AM
Get the proper AC Delco plugs and wires, if needed, in place of the Bosch plugs, whether or not this is the direct problem.
rubberman
10-10-2006, 10:28 PM
i used those Bosch plugs and had no issues yet. took a 1200 trip over the summer and held up fine.25-27mpg
Texas10
11-05-2006, 02:22 AM
Your problem may be that you only replaced the front rather than a problem with the plugs you used. These vehicles use dual tower coils such that two cylinders are fired by one coil. A mismatch in the plugs results in a different energy distribution in the plugs such that one cylinder may misfire. The condition may change with load. I've seen some cases where the engine will barely run.
tec5120
11-26-2006, 08:17 PM
donot use bosch plugs in gm vehicles.use only ac delco.or you will ask for problems .isee it 6 out of 10 vehicles:nono:
Judysvan
07-11-2007, 10:28 PM
Used the AC replacement plugs on all 6. I get 32mpg on the hiway with dual A/C and extended van.
