Dumb Question
stieh2000
10-07-2006, 09:38 PM
If I am going to use PVC pipe to replace the air intake baffles, I need 3" diameter pipe, right? Thanks.
Mr. Luos
10-07-2006, 10:01 PM
LS1??
If so...Fernco 3" coupling.
92zcamaroperson
10-08-2006, 08:09 AM
yeah what he said 5 bucks at home depot. stick it in the microwave to soften it up a little. obviously take the clamps off first. Works like a charm and is a heck of a lot better than paying 50 bucks for the same things. It may not fit perfectly at first but with the engine heat it will conform. dont use pvc.
stieh2000
10-08-2006, 11:54 AM
Actually its a 3800, not LS1, but close enough. Why not PVC?
Mr. Luos
10-08-2006, 02:03 PM
That stuff is solid.
2.2 Straight six
10-08-2006, 02:05 PM
some of it. poly vynyl chloride (pvc) can be anything between solid to a soft rubber-like material.
stieh2000
10-08-2006, 03:31 PM
Well I found some PVC that deffinatly is solid so that is why I was asking about using PVC. Thanks anyways, I'll guess the next time I'm in HD I'll pick up a Fernco 3" Coupling (whatever it is) and use that.
